noise from the rear
noise from the rear
here is the problem i got. i found there is kinda noise comes from the rear of my car, it hard to describe wut it likes, but i'm sure that is not come from the exhaust. noise gets stronger as the speed goes high, can someone please tell me what is going on with my car. by the way my car is 98ex coupe.thanks
Re: noise from the rear (lionhart)
my car has a strange buzzing noise when i drive and it gets louder as i drive.
the mechanic said it was eiher the fuel pump or a rear wheel bearing.
my car still drives so i don't care
Re: noise from the rear (Soulless)
There are a few things it could be. Is your car lowered? If it is have you put camber kits in the rear? If not then the noise you could be hearing is that of the tire. Typically in cars with camber problems the inner edge of the tire gets chopped. When this happens it makes a noise very similar to a bad wheel bearing(not as loud), and obviously it increases with speed.
If it is a wheel bearing there are two easy test you can do. One, when you are driving straight move the car side to side slowly. If the noise goes away when you turn one direction, but gets louder when you turn the opposite direction, then it is a wheel bearing. Two, jack the car up at the rear and wiggle the wheel. If it is loose then it's a wheel bearing.
Good Luck.
Good Luck.
