need help on search
need help on search
ok i know people are gonna tell me to search when i ask this question and i would liek to learn the right way to do it. for some reason when i search i cant fins the right key words to find what i want to know. i am doing my b18c swap into my 93 cx hatch and i need to know how to run the vtec wires to the ecu. the engine harness im using is a obd 1 harness from a 95 gsr and im also using a 95 gsr ecu. i know it will plug right into the ecu plugs i have in the car but i cant remember which pins to add the vtec wires to on the plugs. i have only done swaps in non obd cars like 89 hatches and crx's. i am not asking for a handout whe i know i can search i just need to know what to type in the search field to bring it up. i cant find anything except a post about a 2000 si wiring harness please help guys thanx
Re: need help on search (FifthGearOnline)
WTF does that say
Here's a useful write up on C-Speed Racing :
http://www.c-speedracing.com/howto/b18cswap/swap.php
Re: need help on search (nextelbuddy)
for the VTEC pin-outs, do as follows
VTEC Solenoid - A4 pin-out
Oil Pressure - D6 and ground (Grn/Wht wire)
Hope that helps man
Hope that helps man
Re: need help on search (poison)
that does help but i still need to knwo where i can find a picture or diagram of the ecu pinout for the 92-95 civic so i can see what A4 is and what not. i also need to see the diagram so i can see where i add the knock sensot wire to on the plugs too.
i also have another question, can i use the 95 integra grs engine harness in the 92-95 civic i mean will it plug up to the civic ecu harness or am i going to have to use the engine harness off my civic engine and add vtec wires? thanx guys for any help on where i might be able to find the diagram at...
Exactly what you want to do: http://www.c-speedracing.com/howto/b18cswap/swap.php
Also got good info on http://tech.hybridgarage.com/tech/info.html#B18EG6
RoLLn98Ej6
16
05-07-2011 11:19 AM
OshkyCiv23
08-10-2005 06:16 PM
Prevail
04-17-2004 08:06 PM
