Shock Dissasembly
Shock Dissasembly
Trying to get the bolt off the top of the shock, Ive got the spring compressed, it just turns and turns and turns, doesnt come off.. help please?
Thanks,
James
(Its a '98 HB)
Thanks,
James
(Its a '98 HB)
Re: Shock Dissasembly (Syzle)
Oh.. duh.. i think i need an allen wrench in the top of the shock to keep it still, I think.. while I turn the nut, so the bolt itself doesnt turn... hard to explain.. but i sat there and turned it for 15 minutes without it, is that gonna mess something up> lol..
You need to use an allen wrench or you can impact it off. Just hold the strut and impact the nut off. It'll come off because the impact has so much power.
Alright the hex nut is stripped I dont know how the **** it is, the allen wrench wont hold the bolt in place while I get the nut off.. how the hell do I fix this??? I know you guys are looking at this.
Thanks
Thanks
just take the shock to a car shop, they should do it for $5-10. It is really easy with an impact wrench.
I hope you are installing new shocks.
Solbros Owns Me
Re: Shock Dissasembly (CRX25)
if you're not using the shocks again, just use locking pliers and grab onto the shaft of the shock.
Even if you're using the same shocks, use pliers up by the mount, where the shaft isn';t going to go into the body of the shock.
I usually use an impact, but I've done this a few times and no problems
Re: Shock Dissasembly (Evs-One)
Ill try with the pliars tommorow, thanks. Oh yeah, I took the nut off the first shock while everything was still bolted up, and letting the spring decompress while jacking the car up.. well.. this sucked, because I had to compress the spring while the shock was in place because it was too long to extend itself all the way, even with the damper fork bolt off... it would work if I had shorter springs, but not on the stockers
Could you elaborate with the pliars idea? The shaft I can't get to, because of the dust cover.. maybe if I keep compressing the spring enough?
GDD Member
chris215chris
08-17-2003 08:18 PM
