HELP: Exam tommorow + car won't start
The car is a 92 vx and had a dx motor swapped over, everything worked fine.
Now, when you try to start it the motor won't turn over. The battery is brand new and everything works (headlights, wipers, etc.) but it won't start. It does however make a loud clicking sound everytime you try to start it.
Re: HELP: Exam tommorow + car won't start (1.8 HB)
starter solenoid.
keep trying. my buddies teg has the same problem. and check the connections, he ground could have come off or somthing.
also if your worried have the battery checked because its POSSIBLE its the battery.
[Modified by Kamin, 4:58 PM 3/11/2003]
Re: HELP: Exam tommorow + car won't start (Kamin)
Have the battery tested, make sure the connections to the starter are good.
If all else fails, the starter solenoid is bad and starter will need to be replaced.
Re: HELP: Exam tommorow + car won't start (fowler)
Try bumpstarting it. It may work, may not.
Re: HELP: Exam tommorow + car won't start (EKology)
might be the cap and rotor, mine went bad, wouldnt provide enough sark and the car wouldnt start. you wont be able to fix that by tomorrow though
MEAT PATTY
Re: HELP: Exam tommorow + car won't start (euclid)
Yeah dude just push start it. I did the same thing when my car wouldn't start and I had to get to class. I've been their and done that. Just a get a bunch of meat head football players to push your toy down the street.
Re: HELP: Exam tommorow + car won't start (goforbroke)
sounds like ur starter is about to give... get a big metal bar and have someone start it while u bang on the starter.... unless u got enough people to push start it... hope it helps... l8rz
Re: HELP: Exam tommorow + car won't start (buddha429)
yea, bang the starter with a mallet or something, sounds like it's about to go out. i've had this problem before on one of my vans. just whacked the starter and started.
Re: HELP: Exam tommorow + car won't start (tominos)
the same thing happened to me this morning in my 1991 integra gs. it would just make a noticable click sound whenever i tried to start it. then after a while of pulling and checking fuses here and there, i tried it again and it started. this has happened to me in this car a few times and usually with persistance, it started. i just kept trying and trying.
Re: HELP: Exam tommorow + car won't start (slomofo)
Starter solenoid. Not sure if someone already posted this, but use a hammer and tap the starter, then start.
jorge59la
09-16-2007 06:28 PM
them8te
03-20-2003 10:09 AM
