doch vtec ecu on a soch vtec
dohc vtec ecu on a sohc vtec
some people say that it can be done and i want to know the truths and lies about all of this so i can know if it can be done or not the motor that i have is the d16y8
thanks
damn iu cant belive i did that was typing fast and didnt relize it so flame on but im not a newbe sorry guys
[Modified by turbo924porsche, 7:06 PM 3/12/2003]
thanks
Re: doch vtec ecu on a soch vtec (boostsohfast)
so it does work do you know what ecu your friend was running and did it throw codes all of the time tell me more
Re: doch vtec ecu on a soch vtec (Zeus Zore)
so there is no performance gains from it
if so, honda would have done it from the start
word
Re: doch vtec ecu on a soch vtec (civictypenos)
my friend bought a bullfrog ecu for his d16, then put it on his gsr and it works fine. so there interchangable, at least a bullfrog one is.
Re: dohc vtec ecu on a sohc vtec (turbo924porsche)
dohc vtec will work on sohc no doubt but there are no performance gains unless your sohc vtec if fully built.
usually vtec, rev limit, fuel maps don't really correspond too well to a stock motor. so by so called upgrading you're doing more damage then good.
also non-vtec d15b/b18b is the lowest common denominator ecu - meaning it will usually run in most cars without setting off a code or running too bad. as its has no vtec, no oil pressure switch, no knock sensor, no EGR (present on h/f series), and fuel/ignition maps which are meant to be very forgiving as far as octane and timing is concern.
Tad
05-29-2004 06:00 PM
