Roof Antenna Conversion for Hatch
I did a search and all I found was about S2000 topics. I want to buy the new SI roof antenna to put it on my 92 hatch. I want to know if someone else has done this with similar antennas. I've seem few pics around with this mod. The main reson I want to do it because my stock antenna is stuck, I could only put it out half way and the reception is horrible.
Re: Roof Antenna Conversion for Hatch (POS Hatchback)
yes, What antenna is that one? Is it pretty simple mod right? I just need to run the wire from the radio throught the roof. Thanks for the pic.
I should be able to find one If I look throgh the VW magazines in the bookstore. I'll do a online search as well. Thanks.
New User
So do you have to drill a hole through the roof for that, or what?
Yes
Yes
Its fairly easy to install. just pull the upper side trim off on the drivers side, remove the plastic screw/clips that hold the roof liner on, remove the rear roof liner trim and install the antenna wire.
When you cut the hole in the roof sheet metal be SURE to put a little etching primer and tough up paint on the edges of the sheet metal or it WILL rust.
Mike
Re: Roof Antenna Conversion for Hatch (92sleepR)
I found this site that sell the MDX/SI antenna $40 shipped with all the hardware and cable. http://www.locustom.com
Re: Roof Antenna Conversion for Hatch (93H22HB)
I don't see it as hard. All you got to do is run the wire and drill a hole, plus it will give better reception, because it is amplified.
Re: Roof Antenna Conversion for Hatch (EG6-SiR)
couldnt you drill throught the window stipping for the rear of a coupe, or come up straight out of the trunk bu=y the roof spoiler on a hatchback.... i dont think you really need to rill holes in your roof. just get creative
the words:mispellings ratio in this post was relly high
[Modified by euclid, 5:29 PM 3/12/2003]
Funny thing is, most of the people who've done this conversion probably never even listen to the radio...
Exactly, I have mine for 2 years now and really don't care for it nowadays. I picked mine up thru some VW show swap meet. The brand, like a few mention, is Zender. I only did it cause back in the days it was cool
Radio reception will vary, even thought its power, really didn't made a different on my application. Its different for sure. However, I've been told you can used other OEM cars, but I'm not sure.
The work involved includes taking off the headerlinear, postion the actual base center correctly and wire down the cable. Not to hard, just time consuming with anything you do that a car.
Re: Roof Antenna Conversion for Hatch (Jun)
