Boost Gauge Vac Line Through Firewall
This either belongs in FI or this forum, I'll post it here I was wondering where you guys went through the firewall with your small vac line? I have a spot on the passenger side where my power wire is running, but that is pretty far away from the a pillar and would have to be a long line. I took a quick glance and didn't see any spots. Thanks.
Nate
Nate
Re: Boost Gauge Vac Line Through Firewall (5thgencivic)
I put mine through the spot on the passenger side where you are talking about (but my boost gauge is in my center console) but you can also put it through the driver's side to the right of the brake resivour (sp?). I wired my alarm through a hole there. It's behind the strut tower also.
right next to the master cylinder/brake cylinder, in the corner should be a rubber boot with the harness going into the car thru the firewall. push the rubber in and you got yourself a nice hole.
K i l l a B e e.
10-29-2007 08:56 AM
