eg front sway bar question
Former Moderator
Re: eg front sway bar question (CXHatchback)
Yes, to GSR ones or 92-95 EX/Si ones.
May I ask the original topic starter:
Why do you want such a big front bar?
You do know that unless you have stiffer springs in the rear or a bigger rear swaybar that that front GS-R bar will only add understeer, which will suck.
Do you currently run a ***-happy spring combo or a big rear bar? I'd imagine that the front GS-R bar alone will only hurt performance, not help.
Former Moderator
Re: eg front sway bar question (hybridcoupe97)
I'd add the Si/Ex front bar and then step up the rear bar to the ITR-spec 22mm or so.
What are your springs rates though? If you're way stiffer in the rear then the front bar might help out with some balancing, but I doubt H&R would set you up with ***-happy springrates.
Former Moderator
Re: eg front sway bar question (junglerunna02)
Junkyards would be your best bet for the 1992-1995 Si/EX bar, and used is just fine.
Jusrt make sure you get some LCAs and the endlinks as well, or you'll be pissed once you jack your car up.
As far as the ITR rear bar goes, thr bar itself can probably be found here in the classifieds - many ITR guys upgraded.
TegoDC5
Suspension & Brakes
14
09-13-2005 08:45 AM
