Who makes the best rear swwaybar for the 96-00 hatchbacks
1 Post
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (Halo)
I'd stick with either Beaks/ITR or Comptech.
Both are basically the same thing. Comptech has a little more bling with it's lower tie bar.
But at the same time, more expensive.
Both are OEM, so you don't have any problem clearing your exhaust..in most cases.
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (fowler)
lol does DC sports suck that much that it doesnt even get mentioned?
I have a Comptech 22mm rear sway. I am very pleased. I would say either the ITR or Comptech are both good bars.
1 Post
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (NeVeR bLoWn)
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (uc0083)
Please correct me if I'm wrong:
Comptech : 22mm
ITR: 22mm
GSR: 14mm
Si: 13mm
progress: 22mm
Suspen Tech : ????
Comptech : 22mm
ITR: 22mm
GSR: 14mm
Si: 13mm
progress: 22mm
Suspen Tech : ????
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (Hooch at 8400-RPM)
i have an EG..so i'm thinking this will relate to the EK...
will a 14mm GSR differ that much from a 22mm TypeR rear sway?? for better or for worse? cuz peeps here claim too big of a bar isn't the best bet.
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (Heinz57)
i'm using the beaks kit on my 97 hatch.
kit includes:
22mm itr rear sway bar
subframe reinforcement plates
si endlinks
beaks customer service
wil is the man
kit includes:
si endlinks
wil is the man
1 Post
As long as you have a bar in the front thats around the size of the bar in the back, you're fine. (that sounded really really really gay)
Like, a 24mm GSR front and an ITR rear would do you just fine.
I use to have the ST kit, after 2 weeks of driving the rear swaybar completely tore out my rear I beam and ran me $1100 to fix...Belive me if you have ever had your Ibeam torn off you will become Ibeam paranoid forever I am using the CTR/Si front swaybar(26mm?) Would there be any added safety if the bar was mounted away from the Ibeam entirely? Like the SRR kit? I am also running 800lb springs in the rear with 950lb in front. Do stiffer springs put less stress on the swaybar or softer springs?
[Modified by Halo, 2:48 PM 3/12/2003]
I would guess that softer springs do because they would cause more body roll/chasis flex. I'm probably gonna go with the Comptech myself though.
correct me if im wrong but if you guys are refiering to the stabilizer bar i would go with mugen. if im wrong stay with honda. im still learning so bear with me.
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (vtecvoodoo)
Honda
First thing I thought when I read the title, then I opened the thread and you stole my answer in the first response
I would go with OEM, or saner. http://www.sanerperffab.com I think is the url. They make custom bars and I believe they have adjustable endlinks. Mike M has a special for jdm itr 23mm rear sways right now. Check the sticky on the best buys page.
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (FritzInTN)
Comptech : 22mm
ITR: 22mm
GSR: 14mm
Si: 13mm
progress: 22mm
Suspen Tech : ????
Comptech : 22mm
ITR: 22mm
GSR: 14mm
Si: 13mm
progress: 22mm
Suspen Tech : ????
Do the ITR w/ Beaks or Comptech.... because you know the old Grand-Am commercials Iaho la ooha (wider is better)
Re: Who makes the best rear swwaybar for the 96-00 hatchbacks (SlippylesKB)
Why then the supposed I beam problems with the ST bar if its a smaller diameter than the 23mm ones? Shotty mounting points or what?
RGoose18
05-08-2006 06:15 PM
