how to do it yourself alinement
on my hatch the alinement is off and the wheel slants a little in. i just wanted to know if anyone knows how to do it without taking it to a shop
Re: how to do it yourself alinement (velvetjones)
no b/c they put it on a machine that reads everything and tells them how to adjust it..to fix the toe a little you can break the nutt on the tie-rod loose and spin that... it will slowly change it. but by all means just take it to a shop and spend the $40 to have it done the right way, and save yourself the trouble.
First of all its alignment ok.
Second no you can't do it, because what the guy above me said.
The shop, puts the car on a machine, which tells them which specs to set the aligment to.
You can adjust the teo of your car, but i wouldn't suggest it, unless you really know what you're doing.
even if you do it yourself, you still need the equipment to do it right, be it an alignment rack, or the alignment turntables.
when you mess with a any cars suspension...whatever specs the alignement machine has wont do you any good because those are set for factory.
the slant that you say you have is normal when you lower a car without using a camber kit. to prevent fast tire wear just rotate the tires and take them to a shop to have them flip them around...(does that make sense?)
oh and if its not going straight thats cause your toe is out of spec...that you could get fixed
[Modified by Joe Millionaire, 8:29 PM 3/11/2003]
Re: how to do it yourself alinement (Joe Millionaire)
it's only camber that can't be adjusted, toe can be adjusted to factory specs.
Re: how to do it yourself alinement (tominos)
like what jaeone is going around saying "it's toe that eats tires." which is true. getting an alignment sets toe to factory specs. if you are even more concerned, get a kit on the front and throw some washers in the rear. bad camber + bad toe = bad tire wear/uneven tire wear.
I know the ROADRACING forum did have a post on this sometime last year good luck.. and they were able to do it in there own garage
so you're saying an alignment won't do any good on a lowered car?
I DL'ed an option video off someone on HT about sus setups and it shows how to align your own car. It looks kind of hard but its possible.
Re: how to do it yourself alinement (Frosty_SPL)
With toe set exactly like this, I was able to go 25K miles before having to replace my tires, and that is with -2.3 deg. camber. As of this past Sunday I had -2.3 on both sides in front, and -1.9/-2.1 L/R in back. Keep that toe in check using an alignment rack (Hunter is usually the most trusted brand of machine) and you should be good.
Re: how to do it yourself alinement (PatrickGSR94)
Can't you just pull up next to a curb and park, then turn the wheel really hard to smack the tire against the curb? It used to work on my Huffy
Re: how to do it yourself alinement (rodrez)
why do people SWEAR the camber is the only thing that effects TIRE WEAR???? get your toe's adjusted, camber will help. and alignment is for safety reasons AS WELL... take it to someone who knows or its your ***.
JamesTheMage
02-28-2013 05:23 PM
mikeunreal
01-15-2006 10:38 AM
drjondurst
21
01-11-2003 04:12 PM
