raising compression on a d16y8
Old 04-03-2003, 09:08 AM
SprayinCX's Avatar
Default raising compression on a d16y8
i want to get my head shaved on my d16y8. i need to know how much to have it cut to raise it to like 10.5:1 or 11:.1. thanks
Old 04-03-2003, 09:37 AM
RyanEJ8's Avatar
Default Re: raising compression on a d16y8 (SprayinCX)
I would recommend domed pistons, over milling the head. Too many possiblities of side effects.
Old 04-03-2003, 09:49 AM
SprayinCX's Avatar
Default Re: raising compression on a d16y8 (RyanCivic2000)
please explain i'm a idoit
Old 04-03-2003, 09:53 AM
RyanEJ8's Avatar
Milling the head gives bad valve to piston clearance issues, and shortens the distance between the cam gear and crank causing more slack on the timing belt. Can get messy.
Old 04-03-2003, 09:54 AM
RyanEJ8's Avatar
There are "safe" limits to milling a head, but I think most people will agree with me that domed pistons are a better way to raise C/R.
Old 04-03-2003, 09:57 AM
Banned
Irishweird00's Avatar
buy some z6 pistons, or some a1 pistons. The z6 would be around 11:5 i think, the a1's would be around 12:5:1 compression.. and the best part about it, they are cheap
Old 04-03-2003, 10:49 AM
SprayinCX's Avatar
Default Re: raising compression on a d16y8 (Irishweird00)
if i go with differ pistons is there the issue about valves clearance or anything else i would have to change?
Old 04-03-2003, 10:52 AM
RyanEJ8's Avatar
With higher compression, there can always be valve clearance problems if you don't tune your timing properly, but it is a better place to start than with a milled head. I will be going to 10.5:1 SRP pistons with my nitrous setup. I might consider 11:1 if I can find someone that makes them for cheap. I know Arias makes them.
Old 04-03-2003, 12:30 PM
vladd's Avatar
i always heard that z6 pistons will give around a 10.3-10.5 cr, and the a1 pistons around a 11.1 cr (in a d16y7/8 block).
Old 04-03-2003, 01:11 PM
Banned
Default Re: raising compression on a d16y8 (civicdxtyper)
d16a1 pistons (stock bore) in the following with a y8/z6 metal head gasket (no mill):
d16a6= 11.08: 1 compression
d16z6= 12.03: 1 compression
d16y8= 12.61: 1 compression
z6 is lower, in the y8 in the 11's i know that
Old 04-07-2003, 11:45 AM
KENetics1's Avatar
Get some jdm zc pistons or 88-89 teg(d16a1) pistons. THey come domed from the factory and there not that expensive and raise your compression a pretty good amount too.
brenen8
02-11-2011 01:44 AM
jdm_sir2
02-17-2007 01:54 PM
96 EX
11-10-2006 10:35 PM
Quick Reply: raising compression on a d16y8
