need help ! car over heat after radiator fluid change
ah damn . . .
i wanna kill myself . . .
i decided to flush the radiator fluid today for my 99 si to add new fluid in . . .
car over heats some damn how . . .
anyone give me any help ?
thanx in advanced
EDIT . . . . i fixed the problem . . .
to me . . . i forgot to bleed the damn thing . . . i guess i owned myself
[Modified by b 1 6 a 2, 8:58 PM 4/2/2003]
thanx in advanced
Re: need help ! car over heat after radiator fluid change (b 1 6 a 2)
Did you re-check everything after you finished? Made sure you tightened everything up? Is it leaking? Need more info.
[Modified by Noe Kozz, 8:35 PM 4/2/2003]
Unceasing Measure
Re: need help ! car over heat after radiator fluid change (Noe Kozz)
Make sure you shut your bleeder valve and tightened your cap all the way. It's funny sometimes that you think your radiator cap is on all the way then it blows off and starts spewing coolant...
Unceasing Measure
is your thermostat working? maybe it's fried and now it stays shut all the time. easy to find out...i'd rule that out before looking into more serious issues.
you're not seeing any thick white smoke are you?
Re: need help ! car over heat after radiator fluid change (Archidictus)
well. Last week when my dad and I did a y8 IM swap onto my y7 we lost alot of coolant (lots) . We put everything backtogether and put some more antifreeze into the radiator..... Start the car and go for a drive. BAM! the temperature skyrockets to H. I dorve the car back home quickly and we were puzzled . My dad opened the radiator and it seemed that nothing was int there . We filled it al the way to the top (you can see through the hole) and now everything works fine .
MAKE SURE TO CHECK YOUR COOLANT LEVEL.
make sure there is enough coolant in the radiator i did the same thing and i found out that i didnt fill up the radiator enough...
also, run the car for a while with the radiator cap off...get all the bubbles out of the radiator.....
BB4lude
18
03-10-2008 05:10 PM
Nightscape
05-14-2005 07:54 PM
TurbothisLS
10-06-2002 05:19 PM
