HELP: high idle
Re: HELP: high idle (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">check for a vacuum leak.
manifold or line off....</TD></TR></TABLE>
yup. a vaccum leak is the most likely reason for it.
Re: HELP: high idle (civicdxtyper)
What Motor? Your from 702 area code, isnt that Vegas? Another problem you might have is the heat there. When i went to Az. i had high *** idles and found out it was the heat there that was messing it up. Cause when i got back my idle was normal. I heard that you could drain out your whole cooling system and refill it and itll work. Im goin to drain and refill mine tomorrow seeing as its the longest day. Hope that helps.
Re: HELP: high idle (Luserkid)
clean the throttle body. my buddy had his car sitting in a garage for a month and when he got it running the throttle body stuck(b/c of dirt build up) at 2k rpms and caused him to staul/idle high. just my .02 on what it could be. good luck
IntegraType-R
11
01-20-2008 11:23 PM
1baddturbosi
03-17-2007 09:17 AM
Matt00
11-03-2005 06:01 AM
