brake swap ?
brake swap ?
i just bought a 95 gsr rear brake swap,i want to put them in my 98 civic is there anything else that i need to replace for them to work in my civic.does anybody have specific how to instructions?thanks in advance
Re: brake swap ? (jcivic)
EVERYTHING will bolt up perfectly on 96-98 civics. just finished my changeover. mine were sourced from a 4dr gsr....but even the e-brake cables bolted up perfectly. no problems whatsoever.
front: swap over the gsr knuckle/hub assembly onto the civic control arms.
rear: use complete gsr trailing arm assembly. use stock LCA's. we opted to use the stock upper arm. if you compare the gsr and civic upper arms, the civic looks a little beefier, so we used it.
while you're doing it, it would make a lotta sense to put on stainless lines and new pads. good luck.
DEMNTD1
19
10-06-2005 12:53 PM
Jdm93civic
11-25-2003 05:16 AM
