Beginner Question for you Normally Aspirated GODS on HT
i have a 98 LS motor in my hatch right now with all the bolt ons. i have crower stage 2's waiting for install but before i install anything i want to get more internals.
can i throw the CTR pistons in my stock LS motor NA? i heard that this can be done.
what will it improve? i never thought you could use vtec pistons on a nonvtec block. what could be some other good choices
1 Post
Re: Beginner Question for you Normally Aspirated GODS on HT (HybridHackBatch)
Yes you can. You're compression will be around 11.6-7:1
Which is good for a set of big cams. As far as gains go, I'm not sure how much it will improve, but there will be a little bit more torque.
it can be done. Just use LS rods. It should bump the compression up to around 11.4:1. That should be good for a little over 20 hp.
Re: Beginner Question for you Normally Aspirated GODS on HT (EF9_SiR)
sweet
so i can use my stock LS rods that i have in the block right now? thanks for the replies guys
