D16Y8 intake manifold on a D16Z6 head?
Old 06-21-2003, 04:52 PM
JSPECHB's Avatar
Default D16Y8 intake manifold on a D16Z6 head?
Can you do it? Whats it take and will it make a good improvement over the D16Z6 manifold?
Old 06-21-2003, 05:31 PM
RacerBoy's Avatar
Default Re: D16Y8 intake manifold on a D16Z6 head? (JSPECHB)
It bolts right on to your head with no problem. Their is an improvement because the manifold has bigger runners on it. I'd only do this mod if you have some head work and other misc bolt ons.
Old 06-21-2003, 08:01 PM
JSPECHB's Avatar
Default Re: D16Y8 intake manifold on a D16Z6 head? (RacerBoy)
Cool, thanks man! Would this be better than getting a SKUNK2 or VENOM intake manifold?
Modified by JSPECHB at 12:13 AM 6/22/2003
Old 06-21-2003, 09:38 PM
aira
Guest
Posts: n/a
i've done this mod. i only got better throttle response and that's it. just like racer boy said, only do it if u have a lot of mods.
Old 09-17-2004, 08:05 PM
BoRiCuA's Avatar
Default Re: D16Y8 intake manifold on a D16Z6 head? (aira)
i heard that their is a diff in gaskets between the z6 and the y8, something about a coolant? n1 know
Old 09-22-2004, 05:42 AM
BoRiCuA's Avatar
Default Re: D16Y8 intake manifold on a D16Z6 head? (BoRiCuA)
ok now i know i need to cover up the injection holes with jb weld, if n1 has done this how did you cover up the holes? the other 2 things i have a problem with is what goes connected to the nipple in the middle?ok here is a link of a pic i found, https://honda-tech.com/zerothread?id=546057 the hole is between the 2nd and 3rd arrows, right above the hole is the nipple, well it's actually the outlet to the nipple. also in the back far right corner of the IM is a very tiny nipple what goes connected their? trying to find a pic for but can't. any help will be appreciated thanks
PrettyMuchBoned
24
04-16-2014 11:48 AM
acro1010
09-10-2010 01:09 PM
red_hatchback
05-01-2005 03:40 PM
Spoolin84Gsl-se
06-25-2004 02:56 PM
flat-blk-HB
07-04-2003 07:22 AM
Quick Reply: D16Y8 intake manifold on a D16Z6 head?
