Mysterious Fluid spraying.... do motor mounts contain fluid?
New User
Wondering if there is suppost to be fluid in the motor mounts. Recently, some sort of fluid has been spraying out onto the bottom of my hood over the driver side top motormount, powersteering area of the engine bay. The fluid is black and stains the bottom of my hood... it isn't oil or powersteering fluid. This is really confusing me... there seems to be no leaks either.... just every few days, there will be new sprays of this liquid under my hood. please help.
thanks in advance
Cliffnotes - Mysterious fluid spraying under hood in the general area of power steering and drivers side upper motor mount.
thanks in advance
Re: Mysterious Fluid spraying.... do motor mounts contain fluid? (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast »</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
that liquid can **** up ur paint as well leaves stains under the hood
New User
Re: Mysterious Fluid spraying.... do motor mounts contain fluid? (ArinX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX »</TD></TR><TR><TD CLASS="quote">
that liquid can **** up ur paint as well leaves stains under the hood </TD></TR></TABLE>
And it has, hooray
Thanks for all the help
Lastly, how much do one of these motor mounts cost from Honda? Would Polyurethane Inserts suffice?
And it has, hooray
Re: Mysterious Fluid spraying.... do motor mounts contain fluid? (ModlesSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ModlesSI »</TD></TR><TR><TD CLASS="quote">
And it has, hooray
Lastly, how much do one of these motor mounts cost from Honda? Would Polyurethane Inserts suffice?</TD></TR></TABLE>
For the stains, try some Simple Green. Let it soak in SG for a while then scrub it down with a brush and rinse with hose. Should clean it right up.
As for inserts, yes...if your mount was not torn. You my friend have a torn mount which means you will need to A) Get a stock mount from Honda or B) Get an aftermarket urethane mount.
And it has, hooray
Re: Mysterious Fluid spraying.... do motor mounts contain fluid? (EKology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology »</TD></TR><TR><TD CLASS="quote">
B) Get an aftermarket urethane mount.</TD></TR></TABLE>
worth it
worth it
worth it </TD></TR></TABLE>definetely worth it if you can stand a BIG DIFFERENCE in vibration at idle. Outside the car it's not noticable, but inside you'll hear rattles which you never heard before. Place racing gets a for quality and price but a for fitment. Hasport gets a for quality and fitment but a for price. There are also a couple others out there. And a steel wool pad with some simple green works good for the stain. Get it fixed soon before your motor puts a hole in your hood.
Hey, sorry if this has been covered, but I couldn't find it in all the "motor mount" threads. How can you tell if you just need to replace the inserts, or the whole mount. Cuz I managed to find a curb and my front bumper found the wall, and now my mount is leaking REALLY bad. I am assuming I need to replace the entire thing, but I'm not sure cuz I dont know what caused it to break. I'm guessing the jolt of stopping so quick caused it, but again, I'm not sure. TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ModlesSI »</TD></TR><TR><TD CLASS="quote">Thanks guys... problem after problem w/ this turbo =P </TD></TR></TABLE>
If you're turbo, I definately wouldn't go back to a stock mount, move to an aftermarket, stronger one.
Solbros Owns Me
Re: Mysterious Fluid spraying.... do motor mounts contain fluid? (rodrez.)
yeah, 96-00 Civic driver side mounts suck big time.
There are a few options for you....I believe Mugen makes a good replacement as well as HAsport
Guest
Posts: n/a
Re: Mysterious Fluid spraying.... do motor mounts contain fluid? (EKautox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKautox »</TD></TR><TR><TD CLASS="quote">Hey, sorry if this has been covered, but I couldn't find it in all the "motor mount" threads. How can you tell if you just need to replace the inserts, or the whole mount. Cuz I managed to find a curb and my front bumper found the wall, and now my mount is leaking REALLY bad. I am assuming I need to replace the entire thing, but I'm not sure cuz I dont know what caused it to break. I'm guessing the jolt of stopping so quick caused it, but again, I'm not sure. TIA.</TD></TR></TABLE>
Your stock mount isn't really designed to handle the torque loads your putting on it. An insert will give you quite a bit more strength without directing the amount of vibration to the dash/ frame & your kidneys that urethane mounts will.
Re: Mysterious Fluid spraying.... do motor mounts contain fluid? (Motorhead)
I finally got around to doing two of the inserts this weekend (driver side upper and tranny upper, still gotta do the rear tranny) and WOW, is all I gotta say. Big difference in handling.
My old mounts, while not torn visually, were worn beyond belief.
But the vibration - holy moses, is it bad...only at idle though - cruising you can't really tell.
And here is where I picked mine up for cheaper than what HT sponsors seem to be able to do: http://www.suspension.com/prothane-civic.htm
Melissa0901
Honda CR-V & Element
04-25-2016 06:59 AM
Thunder Cat
12-09-2005 03:39 AM
