engine info
engine info
i drive a '94 del sol, and i want to do an engine swap, but i dont really know much about some of the options i could go with, some people have said gsr engine, or ls vtec... but what about a b16 or something... i just dont know much about them. Could anybody give me some sites where i can learn about diferent types of engines, and the pros/cons? So i can decide for myself, other than just listening to everyone, since everyone has their own opinion.... thanks
a b16 in a del sol wouldn't be smart since the 96-97 si's came w/ b16's already, i would personnally put a itr motor in there if you have the cash flow. you can learn on this site, just use the search button
Re: (frosteg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frosteg6 »</TD></TR><TR><TD CLASS="quote">a b16 in a del sol wouldn't be smart since the 96-97 si's came w/ b16's already, i would personnally put a itr motor in there if you have the cash flow. you can learn on this site, just use the search button</TD></TR></TABLE>
for 94-97 there were 3 models
s: d15
si: d16z6 125hp
si vtec: b16a3 160hp.
s: d15
si: d16z6 125hp
Re: engine info (DelSolNoob)
92-95 Del Sol
B18C1
B16A2 Direct bolt-in swap
B18B1
B17A Requires hydraulic transmission or HASport cable clutch conversion Kit
B18C5 (Type-R) Requires OBD-2 conversion wiring
H22A (Prelude) Requires H22A mount kit from HASport or Place Racing
Requires wiring harness modification
B18C1
B18B1
Re: engine info (93VAhatch)
k24a2 if you have the cash.
Light weight, faster and more of a power band than a ITR (b18c5), and iVTEC
If you want to spend like 2 grandish, Id say TURBO.
Build the engine, then turbo. Run 13 psi all day.
https://honda-tech.com/zerothread?id=335078
Re: engine info (CarbonCreations)
Here's the only search you need on where to buy:
https://honda-tech.com/zerothread?id=50010
And cause of the Del Slow's, oops , Del Sol's weight, I'd get a GSR or ITR. IMO.
Re: engine info (D16Z6racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing »</TD></TR><TR><TD CLASS="quote">
And cause of the Del Slow's, oops , Del Sol's weight, I'd get a GSR or ITR. IMO.</TD></TR></TABLE>
so anything over 2400 lbs must use a $4800 itr motor???
del_sol_noob
07-15-2004 05:09 PM
Streetracerx
06-01-2003 07:26 AM
