ITR Rear Sway Bar & Teg LCA in a 00 SI ????????
Hey guys, I have a ITR rear sway bar with Integra LCA. Does this bolt onto my 00 civic with out modification or little modification?? I want to use the Teg LCA cause they are SPC's. Any input would be appreciated, and yes i searched.
TIA
TIA
Re: ITR Rear Sway Bar & Teg LCA in a 00 SI ???????? (JDM CTR EK)
You cannot use any integra rear LCA's on any 96+ civic.
Re: ITR Rear Sway Bar & Teg LCA in a 00 SI ???????? (EF8_Fan)
The LCA's do not bolt up the the 00 Si, but you can use the sway bar with the stock Si endlinks, you just need to buy a reinforcement kit.
Modified by Gump at 10:27 AM 9/25/2003
Re: ITR Rear Sway Bar & Teg LCA in a 00 SI ???????? (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">You cannot use any integra rear LCA's on any 96+ civic.</TD></TR></TABLE>
Unceasing Measure
Re: ITR Rear Sway Bar & Teg LCA in a 00 SI ???????? (chainsaw)
You only need a reinforcement kit if you plan on autocrossing or putting your car through other extremely rigorous handling exercises. You're not going to tear your ******* subframe taking corners at 30mph just because you have a swaybar in the rear.
Yet another example of people who know nothing spraying **** that they've heard in an effort to sound intelligent. The Beaks kit isn't for everybody. Now you'll never have to make that mistake again.
Re: ITR Rear Sway Bar & Teg LCA in a 00 SI ???????? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">You only need a reinforcement kit if you plan on autocrossing or putting your car through other extremely rigorous handling exercises. You're not going to tear your ******* subframe taking corners at 30mph just because you have a swaybar in the rear.
Yet another example of people who know nothing spraying **** that they've heard in an effort to sound intelligent. The Beaks kit isn't for everybody. Now you'll never have to make that mistake again.</TD></TR></TABLE>
Um, I'll be blunt.
You are a dumbass.
There are many people on this board that have torn their subframe in normal driving with a thick swaybar like the ITR, Skunk, and ST.
If you woud rather save 50 bux and risk a $1000 repair, then thats on you. A beaks kits is cheap insurance, and you actually NEED it with an ITR swaybar on a Civic to get the CORRECT ENDLINK ANGLE.
Now everyone thats ever listened to you will never have to make that mistake again.
Um, I'll be blunt.
You are a dumbass.
Don't forget that the beaks kit also come with the endlink collars...without it, the Endlinks won't bolt in correctly with the Type R Sway..
Re: ITR Rear Sway Bar & Teg LCA in a 00 SI ???????? (SLPMDE01)
very true.
Will the beaks kit work with ITR LCA's on a 92-95 Civic... FOR ITR Swaybar?
I have been using the hardware I got with my S/T swaybar, with new bushings from prothane for almost 2 years with 0 problems, but I'm planning on driving harder soon and want to cover my ***...
I'm thinking either Beaks, or machine a custom reinforcement? I want to keep the ITR lca's.
Re: ITR Rear Sway Bar & Teg LCA in a 00 SI ???????? (Gpelsise)
The Beaks kit doesn't care what LCA's you are using.
He has a EG kit on his website for use with the ITR sway.
http://www.beaksproducts.com
jeffk182
13
10-26-2006 01:32 PM
C M S
07-20-2004 05:57 PM
