how many washers to correct camber in the rear?
My car is lowered 1.5 in the rear. I hear that you should have 1 washer per inch dropped. So how many should I use? 1 or 2?
Re: (Tad)
i have some slipstreams and kuhmo ecsta supra tires...205/50/15's. Its not too much camber, but its enough that i notice a sleight wear. Also it is lowered with h&r sport springs and kyb agx shocks.
Re: (VolpeOwnsU)
it all depends on the washer thickness, and how bad your camber is. Cars are all a little different. You just have to try one and if that isnt enough, try 2 and so on.
Re: (Evil_gambit33)
Yeah I put two 3/8", helped significantly but now I have a shitty grinding noise coming from the rear. So I guess I'll have to do the logical thing and raise my car up some
Re: (SOHC_MShue)
with four washers, my camber is still quite a bit negative. i haven't had an alignment yet so i don't know the specs, but i used the 2x4 and a level and it's still neg.
