Question about the vx model.
ok thanks, now one more thing since this thing has a very tiny intake pipe i wanna swap the manifold. wat is a direct bolt in for some more power.
Risky Business
Re: (jdmvic)
Y8 manifold will be your best bet...a Z6 will be good too...all d-series intake manifolds are interchangeable...
Honestly the first thing i would change on that piece of **** motor would be the transmission...look at the difference in ratios between the EX tranny and VX tranny...especially the final drives:
CX and VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
CX and VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
Final Drive---4.250
is this worth it if i plan on swapping it all out later on. and also what kind of gains would i see from swapping the intake manifold.
Modified by jdmvic at 1:58 PM 9/25/2003
The VX has the catalytic convertor on the front of the engine, where as the others are after the header. If you swap to an EX/Si header you will be missing the cat.
D Tranny Guru
Re: (Kikomon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon »</TD></TR><TR><TD CLASS="quote">
what happens if you put a Si final drive on a CX tranny?</TD></TR></TABLE>
A waste fo time.
A waste fo time.
Risky Business
Re: (jdmvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvic »</TD></TR><TR><TD CLASS="quote">so i cant swap any other intake onto there?</TD></TR></TABLE>
EDIT: I guess not...according to Bone. Even though I have read that all D-series intake manifolds are interchangable. Honestly, you wont notice that much of a gain with an intake manifold. Invest in a transmission...trust me...I learned the hard way
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
EDIT: I guess not...according to Bone. Even though I have read that all D-series intake manifolds are interchangable. Honestly, you wont notice that much of a gain with an intake manifold. Invest in a transmission...trust me...I learned the hard way</TD></TR></TABLE>
true just changing the manifold you wont feel that much differnce, now if u were to go about upgrading all those compenents and maybe doing some head work, then you would feel some change, but i would start with a better tranny. i found d series trannys to suck to matter how you look at them for fast shifting but that just my experiences
Re: (jameskersten1)
You really cant just change the intake .. dont forget the VX has a EGR so you will need an intake with an EGR valve attached to it. most of the performance intakes will not have it.. so unless you like driving with a CEL dont bother
im not gonna do an intake swap, my buddy has a vtec engine from a newer honda. i believe it is a d16 vtec from an ex. so ill put that in. but i still got to find a better tranny
I swapped trannys in my VX before I swapped motors. With the VX tranny it was almost impossible to maintain 80 on the highway, without having to downshift to fourth to bring it back up to speed. Cruising around 75 in fifth gear set you at around 2-3K RPM. I slung my main shaft bearing in the VX tranny and replaced the whole thing with a DX tranny. My mileage decreased from around 375 miles per tank to around 275 miles per tank, but it was SUCH a better handling car after that.
a vtec life!!!
09-21-2009 12:08 PM
StorminMatt
16
01-04-2008 08:23 AM
