Rear disk swap and sway bar
Two quick questions.
My car is a 1997 Civic HX - Nothing modded that can get in the way of this, the swap is off a GSR (both the disk and the sway bar)
I have my rear disc swap ready, and it seems to have everything I need. I got Earls lines installed and ready, getting the rotors turned on my way home, and I have new pads ready to go. Is it as easy as it sounds to bolt everything up and be on my way, or have you guys run into some walls when doing a swap. From everything I've read it sounds simple, but I need my car on Monday to get to work so I don't want to risk it.
Also, I have a GSR swaybar that I got from my friend when he upped to a type-r. I have the holes in my LCA's for the endlink mounts, but have no idea where to get them. Hondaautomotiveparts.com is kinda expensive for some little peices of metal is seems. Anyone know where I can get some cheaper?
Re: Rear disk swap and sway bar (jolt-tsp)
Anyone? I'm trying to do the brakes tonight...
got a reply right when I typed that.
Looking for the endlink mounts for the swaybar. The mounts that bolt to the LCA's.
jxhxb
18
10-29-2007 09:27 PM
dynamo
17
08-05-2002 01:08 PM
