what do i need...converting obd2 to obd1
what is it going to take to convert my 98 civic to obd1, i know i need the skunk2 conversion harness but will it be long enough to make it to the ecu since obd2 harness runs through the firewall straight to the ecu?
Re: what do i need...converting obd2 to obd1 (Pho Real)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">The conversion harness you are talking about connects to the plugs that go into the ECU.</TD></TR></TABLE>
right, is that all i need?
Re: what do i need...converting obd2 to obd1 (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">The conversion harness and ECU is all you need.</TD></TR></TABLE>
ok so i am buying a complete obd1 LS swap....now i just get the harness, plug and play?
Re: what do i need...converting obd2 to obd1 (chicken_focker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chicken_focker »</TD></TR><TR><TD CLASS="quote">
ok so i am buying a complete obd1 LS swap....now i just get the harness, plug and play? </TD></TR></TABLE>
You are putting an obd1 LS swap in your 2000 Civic?
You are putting an obd1 LS swap in your 2000 Civic?</TD></TR></TABLE>
yeah whats wrong with that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">It is older than your car, that is against the law.</TD></TR></TABLE>
ha ha ha... berry funny... make me raugh rong time
Re: what do i need...converting obd2 to obd1 (delslo26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo26 »</TD></TR><TR><TD CLASS="quote">ha ha ha... berry funny... make me raugh rong time</TD></TR></TABLE>
I wish that I knew why the hell you posted that....
I wish that I knew why the hell you posted that....</TD></TR></TABLE>
LOL
Putting an OBD1 motor into an OBD2 car is possible. You will need to adapt your OBD2 harness to the OBD1 engine (fuel injectors, convert the dizzy plug to OBD2). The rest will plug in.
For the ECU plugs, you need an OBD2b > OBD1 jumper harness
LOL
Re: what do i need...converting obd2 to obd1 (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Putting an OBD1 motor into an OBD2 car is possible.</TD></TR></TABLE>
It is possible but it is still illegal, correct?
so is going from obd2 to obd1
imo, its easier to convert the motor to obd2 (using obd2 dizzy, injectors, and altenator), use the stock civic harness, then use the obd1 ecu with a jumper harness. unless u mod the engine harness REALLY well, you'll wind up with headache from wiring problems
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">imo, its easier to convert the motor to obd2 (using obd2 dizzy, injectors, and altenator), use the stock civic harness, then use the obd1 ecu with a jumper harness. unless u mod the engine harness REALLY well, you'll wind up with headache from wiring problems</TD></TR></TABLE>
We all know how much fun wiring problems are. I have my own right now.
