Throwing Code 45 & 65 - how to fix?
I have a 00 hatch with an LS swap and i have the CEL on. i just checked and i am throwing codes 45 and 65..
this is what it says for each code:
CODE 45
System Too Lean or Too Rich
malfunction in the fuel monitoring systems
CODE 65
Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
I am running a testpipe and no secondary o2 sensor.
Will putting back a stock cat and secondary 02 solve these codes?
Thanks
CODE 45
CODE 65
Thanks
Re: (superboy)
well code65 seems pretty straight forward to me.
I'm no expert on these codes,
but obviously.. your missing a 2ndary o2 sensor, and it says your 2ndary o2 sensor is malfunctioning.
its malfunctioning cuz ITS MISSING!!! .....
so in otherwords.. dont worry about it,
maybe someone can tell you a trick to get it not to complain.
either that or put a bung for the o2 in your pipe and stick it back in there.
as for the first one.. i'm not sure
Re: Throwing Code 45 & 65 - how to fix? (superboy)
Code 45 is because there's no secondary O2 sensor. Code 65 is because the secondary O2 sensor heater is not working (because its not there).
Re: Throwing Code 45 & 65 - how to fix? (ShowSiMotors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowSiMotors »</TD></TR><TR><TD CLASS="quote">Code 45 will throw also if you hav your secondary O2 unplugged also...i had the same prob in my 2000 si, i just welded a O2 bung in the test pipe and that fixed everything. Any muffler shop can do this if you can't do it yourself
This is a little off topic, but wasnt that civic on ebay?
Re: Throwing Code 45 & 65 - how to fix? (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Code 45 is because there's no secondary O2 sensor. Code 65 is because the secondary O2 sensor heater is not working (because its not there).
sounds like theres your answer!
nothings actually wrong,
just get a bung added and stick ur o2 back in
Re: Throwing Code 45 & 65 - how to fix? (Tad)
He'll still get a CEL with a test pipe, and the 2nd O2 sensor. The 2nd sensor is designed to check that the cat is still doing its job. If the levels of emissions at the 2nd O2 sensor are the same as those at the 1st, the ECU will think that the cat has failed, and kick that code 45 again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">He'll still get a CEL with a test pipe, and the 2nd O2 sensor. The 2nd sensor is designed to check that the cat is still doing its job. If the levels of emissions at the 2nd O2 sensor are the same as those at the 1st, the ECU will think that the cat has failed, and kick that code 45 again.</TD></TR></TABLE>
Wouldn't the ECU instead/additionally throw a Catalyst Malfunctioning code?
importnoodles
03-29-2008 10:20 AM
