CRX si cam in D15 motor...I need help...
My friend and I installed my si cam in my turbo d15b7 last night. Since its a half a tooth off, we moved the belt one tooth over, then advanced the cam gear 2 lines(4 degrees crank). This right? Or should i have line the gear up like stock and put the belt on without moving it a tooth, then moved adjusted the gear alot to compensate?
