NEED HELP. EG9 IS THROWING A CODE AND CAR WONT START......
i finished my b16 swap and its throwing codes. It blinks one long blink then another long blink followed by 4 short blinks. Does this mean that i am throwing a 24 or a 10 and a 14???? Earlier today i started my car and it ran. Then i switched the the air map sensor with the sensor on the back of the throttle body to see if it would solve the code prob. and now the car will start and then die. i switched the pluggs back and now the car is still doin the same ****, starts and then dies. theres a sensor on top of the throttle body which i believe is either a 10 or 14. i had to splice the wires becuase the harness would not reach and i would like to know from any of the guru's, what colors are the wires that go to that sensor because i have another connector thats close to my air map around the same size thats not plugged in to anything. Can anyone help now?
Re: NEED HELP. EG9 IS THROWING A CODE AND CAR WONT START...... (jh)
You have to help us help you. I'm not going to go track down what a code 10 and a code 14 is for ya. Once you find that I'll help you figure it out.
EDIT: I lied. I'm bored
Codes
10 IAT - intake air temperature sensor
14 IAC (EACV) - idle air control valve
There is no code 24.
Codes
