what code is this
what code is this
i have a 92 hatch with a jdm d15b vtec with a p28 auto ecu conv. to manual. every once in a while i was getting a cel, so now it comes on all the time, also my a/f gauge stopped working. i pulled a code 43. i was told by honda it was a fuel supply code but chiltons sayes its a heated o2. which is it?
Re: (95civicracer)
im not doubting anyone, i just wanna be sure before i drop $165 on a new sensor. thats the cheapest ive found around here. is this right?
Re: (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">im not doubting anyone, i just wanna be sure before i drop $165 on a new sensor. thats the cheapest ive found around here. is this right?</TD></TR></TABLE>
If your fuel presure is within spec and there are no large vacuum leaks, it's usually a bad o2 sensor.
Re: (Chiovnidca)
well i dont have fuel press. gauge so i dont know on that, but there are no leaks. the car still runs and idles fine, just getting cel and the mpg is a little worse
Re: what code is this (a1320honda)
Its probably a bad o2 sensor. That may be the reason why your air/fuel gauage isn't working cause it reads off of that sensor. And a bad o2 doesn't properly do your air/fuel mixture and that may be the reason why your getting shitty mpg.
spencedogg
13
10-28-2003 06:45 PM
