Help out a fellow honda enthusiast
I have a JDM B16 with a new radiator, water pump, constantly running fan, and a good thermostat. For some reason when I am on the freeway for about a 30min. drive above or around 65mph it seems to over heat so I put it in nuetral and let it coast for a while and then put it back in gear and the temperature gauge goes back down. This only happens on the freeway. It doesnt over heat during normal stop and go driving, only on the freeway. What do you guys think it is? Thanks!
Re: Help out a fellow honda enthusiast (EG6 SiR)
There's not stuff stuck to your radiator or anything blocking it is there? If anything it should be the opposite since more air over the radiator = cooler engine... maybe it's a thermostat or thermoswitch problem though...
Re: Help out a fellow honda enthusiast (FrostySol)
no nothing stuck, and cant be the thermoswtich because the fan is constantly on because I bridged the connect.
