trying to tweek my suspension a bit.. looking for something like this..
found this online im looking to raise my suspension a bit like .7 i found this but it's for a mazda miata.. anyone seen something like this for a civic..
http://www.metromotorsports.co...D=167
Re: trying to tweek my suspension a bit.. looking for something like this.. (Genedog)
I havent, but they don't seem to difficult to make. If you could produce those you could probally make a killing.
Re: trying to tweek my suspension a bit.. looking for something like this.. (nerdsports)
yes but just a bit.. i need about a 7mm clearance to stop rubbing.. and im looking for something like this or maybe a spring spacer or something.. maybe even putting some washer between the upper shock tower and body.. what do you think to crazy to work??
Re: (MaconPerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaconPerformance »</TD></TR><TR><TD CLASS="quote">I'm pretty sure that I can make those. I have one question, If we go .7 then the 14mm bolts will have little thread to tighten on. ? What do you think? </TD></TR></TABLE>
As long as you don't have a strut tower bar I wouldn't sweat it. With a strut tower bar you probally couldn't swing it. As long as the bolt has all of <U>IT'S</U> threads on the bolt then you'll be fine.
maybe a 5mm could work but i still have enough thread left.. my bar has sunken holes where the nut goes it looks like there is enough space
Modified by Genedog at 11:04 AM 4/5/2004
Go to Pep Boys they have a spring spacers that will raise it back up an inch. I've seen them there. Look around for them near suspension parts. I forgot what they where called but yeah it will raise your springs up an inch. You basically just twist them in and voila.
