ABS Code
Old Apr 4, 2004 | 05:48 AM
aclw2's Avatar
Default ABS Code
Hi, I got a ABS code when I bridged the connector, the ABS light came on 7 times, first 6 are medium pasue and the last one just breifly came on then it repeats all over again. What does this mean?
Old Apr 4, 2004 | 06:37 AM
asmallsol's Avatar
Default Re: ABS Code (aclw2)
if the codes are like the normal ECU codes, it means code 61. Get a helms and it will tell you the meaning of the code.
Old Apr 4, 2004 | 08:07 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aclw2 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I got a ABS code when I bridged the connector, the ABS light came on 7 times, first 6 are medium pasue and the last one just breifly came on then it repeats all over again. What does this mean?</TD></TR></TABLE>
Code 6-1. What year and model?
Old Apr 4, 2004 | 11:53 AM
aclw2's Avatar
Default Re: ABS Code (Chiovnidca)
The car is a 96 Civic EK4.
Thanks
Old Apr 4, 2004 | 12:24 PM
Chiovnidca's Avatar
It is a code 61. The battery voltage being out of range triggers that code. Have you had any problems with the battery lately? Try reseting it and see if it comes back.
Old Apr 4, 2004 | 01:21 PM
aclw2's Avatar
I just checked the battery voltage and it seems to be running fine.
Will reset my ecu to see what happen, if error still stored in my ecu, will this effect the performance of my car?
piers.tremlett
Suspension & Brakes
Aug 10, 2014 02:59 AM
arren123
Jun 18, 2007 04:00 AM
b20acura
Jun 17, 2007 10:53 PM
