EK skirts on EG !?!
EK skirts on EG !?!
How is this done !? i tried 2 search but no help ! i know this has been diskussed before.. anyone that can help me out with a how 2 !?
cause they are longer !? whaty about holes for bolts ?!
THX
THX
Re: EK skirts on EG !?! (Zeus Zore)
https://honda-tech.com/zerothread?id=642479
Try looking through there, there might be a write up. I know i seen a write up done before just keep looking.
cut the ek side skirts so the are the same length as the EG side skirts.
then you gotta drill holes onto your car to fit the ek side skirt clips. then use a file to square out the holes.
Re: EK skirts on EG !?! (Br1anPham)
so you just wanna leave the cuted end open !?! looks bad !?!!? or what ??
**** you really have 2 make new holes in your car for the clips !?! and risk all that rust !?
your fenderliner (correct term?) should over it, if you dont have that then it shows the cut end. if you dont drill then gheeto rig it with double side tape
when i did mine, i cut the fronts off and bought 99-00 mudflaps. some of the holes will line up to just press it in with the clips. you can 3M tape it too. the only bad thing was my car was so low that the mudflaps would scrape.
Re: (spoonfedcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonfedcoupe »</TD></TR><TR><TD CLASS="quote">If you have a hatch you'll have to cut off 2inches on the sideskirt and after that just line up the holes and your done. </TD></TR></TABLE>
not that easy my friend.
Re: (stock93cx)
i installed mine today...
i have a coupe though...
didn't have to cut any at all.. drilled the holes for the clips... made them square with a file... some fit right into the EG spots... pushed the front in and used a screw to hold it in...
fit pretty damn good...
Re: (95DXPhiladeph)
I plastic welded the end piece that I cut off back onto the hole so that it looks like it was never cut. Then I put the fender lining over that. If that makes any sense.
Re: (impound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impound »</TD></TR><TR><TD CLASS="quote">if i was to do this on an eg sedan....which ej(k) model would i use?</TD></TR></TABLE>
the models are the same, for four door, hatch, and coupe. Mike.
Re: (Zeus Zore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> stern: how didd you weld it !? with what !? pics. ???
how many holes are made for the skirt 2 fit !?</TD></TR></TABLE>
I used a saudering gun to melt the plastics together then I smoothed it out by rubbing the saudering gun back and forth.
Then for the holes, the back one lines up and then i just drilled three more evenly apart then secured it underneath with the stock screws, which you have to drill new holes for also.
Hope that helps.
Hope that helps.
Re: (StErN)
stern did it the exact same way i did, except he welded em to look s00per seXXXy y0!
mine were just long enough to fit under the liner also... i only cut off an inch or a little less at a time, so it fit perfect...
Re: EK skirts on EG !?! (scratchy)
it really is a nice conversion like you said...
better than the 5th gen oem sides... they roll under
this gives the "JDM Aftermarket" feel to the car because they are taller and more "boxier"... just look alot better... especially the thing in the back, that little flare in the sideskirt... it looks amazing!
civics4lyfe
03-29-2013 12:27 PM
lpdrew
07-03-2007 02:08 PM
