2000 Civic DX Idle problem
I just changed the oil + filter + air filter, and I noticed that there was a lot of battery corrosion, so I disconnected the battery cable and cleaned it! Now when I drive at idle it shakes and feels like it wants to shut off. It never did this before! Do I need to reset the ECU? And if so, how will I perform this.
Thanks
Louie
Thanks
Louie
Re: 2000 Civic DX Idle problem (louie3888)
disconnect the battery again to reset the ecu, or you can pull a fuse from the egine fuse box next to the battery, it's a 7.5 amp i believe, not 100% sure
Re: 2000 Civic DX Idle problem (Smith Wise)
Ok, I will give it a try. I also heard that after reseting, that I need to hold the rpm's arond 2000 for 1-2 minutes!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by louie3888 »</TD></TR><TR><TD CLASS="quote">Ok, I will give it a try. I also heard that after reseting, that I need to hold the rpm's arond 2000 for 1-2 minutes!</TD></TR></TABLE>
reset and drive around.
cskinner89
07-20-2010 05:12 AM
