how do i fix code 16 - defective fuel injection system
well i posted this in forced induction forum but no one over there seems to know anything except turbo trims ...... maybe i should try in here
my friends car is running like crap. it has no power and wont rev past 4000 rpms and when you rev it it sounds like it is MISSING. his setup is b18c1 arias 9:1 comression he is breaking in motor now and is running stock injectors and stock header and exhaust for break in period. when we first started motor he drove it for a couple of days with no problems and then he ran out of gas one day and alos his timing belt was loose enough for him to jump timing.. we fixed both and now car runs like ****. he is throwing code 16 now... we did a compression test and he got. 180 180 180 180.
any help or advice?
any help or advice?
You need to check the Firing of the injectors and if they are all firing then check the voltage and the injector. I had the same problem one time and it happened when we changed the fuel injectors and had to change the Plugs out. We had to solder the wires and that seemed to help alot. Eventually I changed out the whole wiring harness. The injectors could be miss firing b/c of trash in them.
tom p
10-12-2011 03:58 AM
Nextelbuddy
04-22-2004 07:07 PM
