99-00 Civic fog questions
Re: 99-00 Civic fog questions (maztur)
Here's the whole installation and wiring process: http://www.overboost.com/story.asp?id=205
The grounding wire is connected to the same bolt as the engine grownding wire.
Re: 99-00 Civic fog questions (ilko)
So the bulbs in the OEM fogs are H3's? I was searching for a listing and couldn't find one...
Do you have to remove the bumper to replace the bulbs?
Re: 99-00 Civic fog questions (EX_AutoXer)
Not if it was installed properly you don't.
Just loosen the 4 screws that hold the fog light down, pull it up, and then carefully maneuvre it through the opening. Its as easy as pie.
Re: 99-00 Civic fog questions (SiRGodfather)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRGodfather »</TD></TR><TR><TD CLASS="quote">Not if it was installed properly you don't.
Just loosen the 4 screws that hold the fog light down, pull it up, and then carefully maneuvre it through the opening. Its as easy as pie.</TD></TR></TABLE>
Thanks... I had the bumper off this weekend to install some hella supertones, and I didn't even bother to check. I put in some silverstar headlights, and now the fogs look like ish, so I wanted to get some of those on my fogs this weekend; I just didn't feel like pulling the bumper off again.
I just got my H3 bulbs from the UPS man. It looks as though the bulb is grounded when attached to the car. i.e. the metal bracket around it is grounded, and the wire coming out of it is the power lead.
R-81DC2
13
05-15-2007 09:59 AM
EM1SiR
12-24-2003 08:06 AM
