Z6 HEAD ON Y8 BLOCK
Z6 HEAD ON Y8 BLOCK
i got a complete y8 swap, but my head as taken a **** on me. my friend has a z6 head that he wants to get rid of, would that affect the performance? would it run better or worse?
Re: Z6 HEAD ON Y8 BLOCK (FLATBLACKEG)
i think it would be more of a bitch to put in. You figure that the z6 was an obd-I car and the y8 is a obd-2 car. I'm kinda drunk right now so here's what i think the problems will be....
Parts needed....
z6 head
z6 timing belt
p28 ecu
Problems...
how you gonna run the obd-I into a obd-2 car? o2 simulator for one of the o2 sensors?
will the z6 timing belt work? like does the y8 and the z6 have the same number of teeth?
wiring will be a bitch i think...
compression will be different btw....
Parts needed....
z6 head
z6 timing belt
p28 ecu
Problems...
Re: Z6 HEAD ON Y8 BLOCK (civicshowracing65)
well the y8 is wired up for p28-obd1 ecu, its in my 93 hatch. the only thing im worried about is the performance? i
the Z6 head is the best D series head out there for high-hp applications... but the Y8 head has huge quench...
i want a Z6 head on A6 bottom end in an EK...
True, I have a z6 head on a y7 block and it runs well. don't listen to the drunk guy, all you need is the head, everything else is th same, you migh have trouble bolting your OBDII dizzy to the OBDI head, i used my friends OBDI dizzy and wired on my OBDII plug from my original distributor.
No offence Drunk Kit
keepinitsimple
02-17-2005 11:32 AM
