grinding/chatter
grinding/chatter
94 civic dx;
syptoms: first, this happens in all gears when clutch is engaged. Second, it happens only for a range in upper RPMs but as i do not have a tach i don't know the RPMs. Ex, in 5th gear no noise untill about 70-75, then slight chatter, then from 80 up no noise. Thanks for your input.
Re: (2FAST4U831)
i searched and came up with this
"you know your throwout bearing is bad when you hear a faint grinding sound as you push the clutch in (down) and it goes away when you release."
I do not have this syptom???
zrs6v4
06-09-2013 12:01 AM
