NEED TRANSMISSION HELP
i have a 99 civic ex, 5 spd, 98,000 miles and second and third gear grind. Occasionally third gear will just pop out of place and second gear will always pop out of gear when i am not giving it gas. So if i am just decellerating in second gear, it pops out. I have a skunk 2 short shifter installed as well. I am sure it is the tranny but being that i want to sell this thing are there any ideas or solutions to my problem. thanks
Re: NEED TRANSMISSION HELP (revilo)
WEll your shift linkage is prolly off somehow, my mazda did that for a while and that was the problem. the grind is most likely from bad syncros, but i would put in GM syncromesh friction modified. do a search people will tell you what they thought of it. Didn't help my grind, but it is only oil, and it has helped tons of others.
Re: NEED TRANSMISSION HELP (civiccpedx)
Popping out of gear = bent shift forks or shift linkage binding. Make sure everything is moving smoothly. I second some GM Synchromesh
Jaydeep
12-22-2009 08:38 AM
ATpossible
12
03-03-2007 05:52 PM
