Check Engine Light NO Codes Bogging At 4K
Can You guys Give me A Hand.
I Got a 92 Hatch Si Stock w/D16z6 Motor.
I Had a Problem Starting the Car at First.
To Find out why it did not start was the Tranny Ground (Located Engine Bay by the Hydraulic Clutch Line)
Now It Starts up Fine.
The problem is that the Check Engine Light Stays on.
Jumped it and No Codes Flashes??? "0" Codes. With the Engine Light ON.
Also it will not Rev Past 4000 rpm??? (it boggs out really bad when you rev it)
At the Same Time the Exhaust Smoke From the Tail Pipe is Seem like its Running So Rich That it Burn your eyes.
I Tried to Troubleshoot it as much i can Think. Main Relay, Fuses, Fuel Pump, Ecu, Grounds, Even Disconecting the Viper Car Alarm, Checking the Engine Hardness, Battery Thats about all that i've done.
Can someone out there Give me a Big Hand On This.
I would Appreciate It Very Much.
Banned
Re: Check Engine Light NO Codes Bogging At 4K (_Edge.ONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Edge.ONE »</TD></TR><TR><TD CLASS="quote">Your car is in LIMP mode.. bad ECU.</TD></TR></TABLE>
try a buddie's ecu. as long as its obd1 it should start
Re: Check Engine Light NO Codes Bogging At 4K (alotawatts)
Thanks For The Help.
Any other ideas before i Try The ECU LIMP!
Anything Any Other Ideas???
Re: (slamdcivic)
Just Checked the ECU. It works Fine. Used A Buddys Stock P28 and still same Thing. Flashing Check Light.
I Dought it the Dizzy.
Any Other Assist Guys??
Im Thinking Its either a False Relay or a bad Connection???
Re: Check Engine Light NO Codes Bogging At 4K (spoonhatchblack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonhatchblack »</TD></TR><TR><TD CLASS="quote">The problem is that the Check Engine Light Stays on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonhatchblack »</TD></TR><TR><TD CLASS="quote">Used A Buddys Stock P28 and still same Thing. Flashing Check Light.</TD></TR></TABLE>
So which is it?
So which is it?
Re: Check Engine Light NO Codes Bogging At 4K (powerfulperformance)
i'll check the tps.
but other than that.
does anyone knows how to trouble shoot any relays or wirings??
Advise Please.
Advise Please.
Just Found out it was the ECU. It first 2 ecu's were burnt.
But whats weird is that w/the stock p28 ecu the engine light is still on w/code: #1 (O2 Sensor)....I switched it with another O2 and still the light still stays on???
The check light did stay off for a good 2 seconds......But Flashes on AGAIN!
Oh yea the BOGGING is now GONE 4 GOOD.
What cAn be the Problem now?
Any Advises?
You Guys or Anyone Reccomend taking it to the Dealer for a Diagnoistic Test?
Or Does the Dealer Basically Check my Good Sensors and Charge me a FAT $$$?
Help Please.
Any Advises?
Help Please.
Re: Check Engine Light NO Codes (spoonhatchblack)
let see switched to known good ecu, cel for o2 sensor replaced o2 sensor. so now it cel flashing again. so what are the codes?
Re: Check Engine Light NO Codes (2lua)
yes.
swapped out bad ecu for good ecu.
check light for o2 swapped out o2 for good o2.
and light still flashes for o2.
codes are:
and
#61
help
codes are:
and
#61
help
Re: Check Engine Light NO Codes (boricuatuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boricuatuning »</TD></TR><TR><TD CLASS="quote">Make sure your reset the ecu after installing the good 02 sensor. It will clear all your codes.</TD></TR></TABLE>
ding ding ding we have a winner............unplug your battery for about 10 seconds and it should reset your CEL
Re: Check Engine Light NO Codes Bogging At 4K (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Yup...constant CEL means its an ECU problem</TD></TR></TABLE>
Just Swapped the o2 and resetted the car..........same thing..
it seems like it got worse...
Im not too sure if autozone can advise me..but it doesnt hurt to try!
Any Other Ideas???
Any Other Ideas???
streetchemistry2000si
12-15-2008 09:42 AM
dingusjt
10-16-2003 09:18 AM
