Has anyone ever herd of this!!!!
OG triple OG
today i was driving and all of a sudden my lights turned off , my radio turned off , and my motor shut off with a CEL.....troubleshooting narrowed it down to my under hood fuse box!!!!!!!!! i could wiggle the ground wire that goes into the fuse box and the car lights would go on and off. has anyone ever experienced this?
Re: Has anyone ever herd of this!!!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Loose ground then? Tighten it down and you should be good to go. </TD></TR></TABLE>
Yeah, maybe it has something to do with a loose wire in the dizzy too becase this kind of thing happened to my friend the other day, but no CEL just turned off. I don't know, but it is worth a shot.
OG triple OG
Re: Has anyone ever herd of this!!!! (R33CIVIC)
naw i tried tightening the ground wire down , it was tight
its the contact inside the fuse box . the wire looks really good . if i take the wire off and pry the little metal thing up on the box it works...so i know its the box . how wierd is that!
Re: Has anyone ever herd of this!!!! (Hella_JDM)
kind of crazy that it just decided to come loose.
EDIT: atleast you found the problem...
OG triple OG
ya man everything just started ******* up randomly in my car. my speedo started acting wierd then shut off.....my hazards stoped working along with my turn signals....then it it started shuting off . wierd huh?
never heard of that problem, but atleast you figured it out. Maybe you need some rotas on your hatch, i heard that by putting rotas on a car you wont have any problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">today i was driving and all of a sudden my lights turned off , my radio turned off , and my motor shut off with a CEL.....troubleshooting narrowed it down to my under hood fuse box!!!!!!!!! i could wiggle the ground wire that goes into the fuse box and the car lights would go on and off. has anyone ever experienced this?</TD></TR></TABLE>
umm there arent any ground wires in you fuse box... they're all (+). it's no suprise that you electrical stuff went nuts. your symptoms actually sound like you had a bad altenator. good thing it was an easy fix tho
OG triple OG
it did seem like a bad alt!!! my voltage while driving would go up to 12.8 , then down to 11.9 it never got to 14 at all.....so wierd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">it did seem like a bad alt!!! my voltage while driving would go up to 12.8 , then down to 11.9 it never got to 14 at all.....so wierd.</TD></TR></TABLE>
yup sounds like the alt to me too
I had that happen in a 1974 Firebird I used to own. It's pretty scary as your riding down the road, and all of a sudden your car shuts off.
