Aftermarket Tach
Aftermarket Tach
A friend of mine gave me his aftermarker tach, and its cool so why not install it? So i looked into it and there are like four or five wires. I assume ground, power, dim, and the rmp (ill call it rpm input) I really dont want to splice into my distrubutor becuase that required running wires into the engine through the firewall, which blows. So my question is dose anyone know of the exact wire that is somwhere behind the dash that will give me what im lookin for? my cars a 98 civic ex
Re: Aftermarket Tach (nighttrain33)
What "exact wire"? You'll need one for the power, one for the light switch, one for the ground, and the RPM input signal wires.
Re: Aftermarket Tach (userdead626)
signal wire is blue, you can tap into it (upper right corner of the engine bay, closest to the driver side...the signal wire is the "rpm" wire, you can tap into it at the dizzy up to you.
Re: Aftermarket Tach (R33CIVIC)
I'm sorry, I was thinking one in the gauge cluster. Stupid me. Sorry for the post. Maybe we should just forget I said that.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">I'm sorry, I was thinking one in the gauge cluster. Stupid me. Sorry for the post. Maybe we should just forget I said that.
-Shane</TD></TR></TABLE>
We could forget, but it's entirely much more fun to flame you hehe
After Market Tach will have more than the positive and negative wires. You will have two wires for the lighting alone, one (blue) for the sensor and the other two give the tach itself power.
Im thinking of getting one as well. but then now i figular stock CTRs tach can goes up to 10k i will be happy to find one. hate those big thing beside A-pller
Re: (userdead626)
theres a blue wire that is wired to your stock cluster.
but that goes through a whole bunch of **** and filters, hence the reading not being 100% accurate, hence getting a aftermarket one.
but if you're using the same input, It'l still suck.
do it right, and plug it to you distributor. it's only 1 wire.
if yo dont' have AC, there a nice big hole for you near the battery on the passenger side for you.
