b20 vtec set up whats needed??????
i know i need the golden eagle b20 vtec conversion kit what else do i need??? does the head bolt up (b16 head) will that bolt up to the b20 block??? and the valve clearence will it be ok with stock pistons??? im going to put valves in my head and itr cams and arp rod bolts and head studs but i need to know what i need to do to make this work all info if that would be ok
thanks
thanks
Re: b20 vtec set up whats needed?????? (DohcVtec1992)
you could do a search on H-T and find many threads im sure.....also you can check out: http://www.b20vtec.com....hes got some good stuff on there, parts list, HP #'s...etc...etc
Re: b20 vtec set up whats needed?????? (hybridej7)
what kind of si parts do you have and thanks for the site i joined it and put a post up the name is b20eghatch92
