d16z6 and d16y8 harness question - -
Re: d16z6 and d16y8 harness question - - (crzyfool24)
the injectors, alternator, and distributor plugs will be different. the Z6 also doesnt not have 2 O2sensor plugs and it doesnt have a plug for the crank position sensor. otherwise most things would work. it would be easier to have a Y8 one though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crzyfool24 »</TD></TR><TR><TD CLASS="quote">Will a harness from a Z6 fit onto a y8 motor or do I have to get a y8 harness? Thanks </TD></TR></TABLE>
Just use the z6, it'll work fine.
Re: d16z6 and d16y8 harness question - - (Lee_Delso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso »</TD></TR><TR><TD CLASS="quote">
Just use the z6, it'll work fine.</TD></TR></TABLE>you will have to use the Z6 injectors, alternator and repin the dist plugs because i dont think the Z6 dist will work on the Y8 head. so it wont work fine.
Re: d16z6 and d16y8 harness question - - (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">you will have to use the Z6 injectors, alternator and repin the dist plugs because i dont think the Z6 dist will work on the Y8 head. so it wont work fine.</TD></TR></TABLE>
The distributor will work but the mounts won't line up so you have to make the hole bigger on the distributor to fit the screw in. I just did a 93 Del Sol Si and dropped in a d16y8 and it works fine with out any check light problems. But if you can get a d16y8 harness then that will be better.
91integraLSVTEC
09-14-2007 01:02 PM
rasinhell
01-18-2005 08:24 AM
alternator, d16y8, d16z6, distributer, distributor, dizzy, engine, fit, harness, make, motor, repinned, repinning, y8, z6
