Anti-Freeze goes here or there?
Are you supposed to pour antifreeze directly into the cooling fan through the radiator cap hole or do u fill up the white reservoir to the left of the fan that has the hose going to the fan??
Re: Anti-Freeze goes here or there? (just4747)
the coolant doesn't go into the fan it goes in the radiator and through the motor. the fan just pulls air through the radiator to help cool it. what are you trying to do refill the system after a flush or are you just adding coolant ?
Re: Anti-Freeze goes here or there? (white ex)
just adding cause once in a while, i cant see any coolant under the radiator cap or in the reservoir...so where should i pour it in when adding new coolant??
If you engine is hot you can add fluid in the overflow bladder, if you engine is cool you can add into the radiator. Be sure not to confuse the overflow with the Wiper fluid canister.
you should top off the radiator ( when cold ) and fill the reservoir up to a little more than half way between the min and max lines. do you have any leaks cause the reservoir shouldn't empty completely.
nope..it wasnt completely empty though so thats good...just a little low...but when u open the radiator cap, its okay to not see any coolant right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ex »</TD></TR><TR><TD CLASS="quote">you should top off the radiator ( when cold ) and fill the reservoir up to a little more than half way between the min and max lines. do you have any leaks cause the reservoir shouldn't empty completely.</TD></TR></TABLE>
This happens to me over a long period of time. What is the best [ easiest ] way to check for leaks?
fuglybutruns
07-28-2015 07:50 PM
TailZ
Honda Civic (2001 - 2005)
06-14-2010 10:52 AM
spock_rocker
06-06-2005 03:32 PM
PearlWhiteAccord
09-25-2002 12:15 PM
