h22 swap missing at part throttle eg
when i am just riding along at 1/4 or 1/8 throttle sometimes it misses pretty bad. doesnt always do it. may go 10 or 15 miles and it wont do it. checked the codes= none found. tried new plugs. i have a spare h22 that i know everything is good(i pulled it). i swapped wires, cap, rotor button, and then distributor. nothing helped. for some reason i unplugged the tps and it quit. not one miss in about 40 or so miles. of course the cel came on. so today when i got off work i dug out another tps sensor and put it on. set my voltage to idle .5 volts and wot at 4.53 volts. reset the ecu and cranked it up. seemed fine. drove 10 miles to the store to get gas. started missing on the way home. if i floor it, the miss goes completely away and it runs like always. i dont know what else to try. help my set up is
95 cx
93 jdm h22a
hasport harness
p72 ecu
92 accord resistor pack
i have put about 12k on this setup.
95 cx
93 jdm h22a
hasport harness
p72 ecu
jdm 1080p
10
02-11-2013 06:08 AM
