Does This Swap??? -Disc Conversion-
A rear disc conversion which came off a 2000 GSR. I just need to know if this will fit onto my 95 Civic Coupe. I've read that they will definately fit as long as you swap from the same year teg. Just want to be sure before spending the cash. If anyone can help I would greatly appriciate it!!! Thanks
Re: Does This Swap??? -Disc Conversion- (slice125x)
sorry to rain on your parade, but you REALLY need to search this. This has been discussed many times in here and in the hybrid forum.
I even think that it might be in the faq at the top of this forum, but not sure.
This has been covered 100000 times in the past 2 weeks, and 104801484308 times before that.
Use the search, there is so much information on this topic you couldnt read it all in a week.
yes they will fit
here check this out https://honda-tech.com/zerothread?id=1024818
and if u need help on the swap...check this one out, it shows the fron and rear
https://honda-tech.com/zerothread?id=820484
Re: (AzntaggeR)
Thanks AzntaggeR and JDM BoI
I am new to this site as of today and somebody offered to sell me this setup... I'm very sory to bother those of you who don't want to answer question for people. It just seems so much faster to ask then to search when your under time constraints. If your bothered by a question don't anwer it. Read something u r interested in, as I'm sure that every question and for that matter every answer has been spoken of more than enough anywhere you look... Is this not the reason forums such as this one are offered? To ask questions and provide answers?
I'm sorry that I may have offended a few of you. Though of the two posts I've placed today, I have to compliment the fast and corteous response of most of the members on this forum... Thanks to everyone!!!
And Thanks again AzntaggeR and JDM BoI!!!
Re: (slice125x)
i wasn't being negative, and i don't like when you are negative towards me. I am a little offended when you don't read the forum rules. Search then post, not post then search, just try to abide by the rules to keep clutter down thats all.
Good luck with the swap.
Re: (slice125x)
I know that you already have your answer, but yes they will swap right on. I know that people on here are quite mean sometimes, but it is helpful to read more than to post, even if you are in a time crunch. The search takes a little bit of time to get used to, but is VERY helpful once you do get used to it. Good luck, and make sure to heat the bolt up pretty well before you try to take them out, as this is very helpful!!
-Shane
-Shane
Re: (slamdcivic)
Only the Type R's brakes (besides the obvious 4 lug/5lug difference) are not the same. Those are the only one's (to my knowledge) that won't swap with other Civic/Tegs.
-Shane
-Shane
