****ek civic pwr windows going up slow****
i called the dealer to figure out what to order and theres regulators and motors and even the tracks could cause this problem, just wonderin if anyone had this problem and what piece fixed it? im leaning tword regulators.
Re: ****ek civic pwr windows going up slow**** (jdmpsicivic)
Is it both windows? if its just the drivers side I'd say the motor. Check ebay if you don't buy from the stealership
Re: ****ek civic pwr windows going up slow**** (Who Dey)
its most likely not the motor. at 60k miles i believe...they grease the rails. its probably just out of lubrication
Re: ****ek civic pwr windows going up slow**** (#1151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #1151 »</TD></TR><TR><TD CLASS="quote">its most likely not the motor. at 60k miles i believe...they grease the rails. its probably just out of lubrication </TD></TR></TABLE>
i second that
i second that
Re: ****ek civic pwr windows going up slow**** (Redline96LX)
im having the same problem...but im using aftermarket power windows...and when its really cold outside, the window gets stuck while rolling down...is it because it needs lubrication..?
The motors do go bad as well, causing slow roll ups.
Re: (yoej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoej8 »</TD></TR><TR><TD CLASS="quote">i just used silicon spray, not sure if there are other more proper lubricants out there</TD></TR></TABLE>
yep. works like a charm.
Re: (yoej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoej8 »</TD></TR><TR><TD CLASS="quote">i just used silicon spray, not sure if there are other more proper lubricants out there</TD></TR></TABLE> i used white lithium grease on my mother's camaro...worked like a charm for her car. but i hear tat it is only a temporary fix. find out what they use at the stealership...ide recommend that
Re: (#1151)
i was a lube tech at honda and everyone there used Silcone spray. that is what i have always heard to use before there and when i worked there. I'd say spray some in rails and roll it up and down a few times see what happens. wont hurt it can only help it.
clubEmoKiller9
07-16-2006 05:02 PM
