installing oil press gauge (question)
hello everybody.
i got a autometer ultra lite oil press gauge.
on the diagram it says that i need to run a wire from the gauge to the ignition switch....
where is it?
thanks...
where is it?
thanks...
Re: installing oil press gauge (RACEPAK)
what they mean is that you need to tap into a wire that is powered with the ignition on and off with the key off. The easy way is to just grab it off of your radio harness.
Re: installing oil press gauge (SamB16)
Or, since honda engineers were so brilliant. You could use one of the spade connectors on the fuse block, that were put there for accessories. I belive there are either 4 or 6 of them. Some have constant power, others are switched power.
are u sure thats not the wire for the light? because my oil gauge only needed the oil line then the other 2 wires were for the light
Re: installing oil press gauge (1sikhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch »</TD></TR><TR><TD CLASS="quote">are u sure thats not the wire for the light? because my oil gauge only needed the oil line then the other 2 wires were for the light</TD></TR></TABLE>
Sounds like a mechanical gauge... He's probably talking electrical
