CKF question
CKF question
hi,
I have a 99 cx with an a6 minime swapped in. the car is converted to obd1 with a chipped p06 running hondata s300. ok so the way I under stand it is an a6/z6 doesn't have a CKF sensor mounted on the oilpump like the y7/y8's, I was told it is in the distributor. is this correct? for my distributor I'm using a z6 housing with the guts from my y7 distributor swapped in. I did this so I wouldn't have to change around the plugs. but now I'm thinking the y7 distributor wouldn't be wired for the CKF since on y7 the ckf is on the oil pump. the reason I ask is because my car is misfiring and not idling right. it's not throwing any codes though, so it makes diagnosing the problem a little tough.
any help would be appriciated,
B
B
twizted-myatt
05-31-2011 02:34 PM
