Throttle body opinions
1 Post
I have a D16Y8 built bottom end
10.5:1 SRP pistons
eagle H beams
balanced
head studs
I/H/E
adj cam gear
ACT flywheel and clutch
Skunk2 Intake manifold
My previous intake was an auto so I have to replace the throttle body (good excuse to get an aftermarket one). What is a good size for my engine and what has all the sensor spots. I see the edelbrock come with a TPS which I like but shows it only for B16/18's but from what I've seen and read there all the same on the Honda's. what sensor is on the top of my TB now I was thinking it was the MAP sensor do any aftermarket TB's have the place for this? What about the FITV I know everybody says junk it but it would be nice to have all the benefits of OEM pieces.
10.5:1 SRP pistons
eagle H beams
balanced
head studs
I/H/E
adj cam gear
Re: Throttle body opinions (dohcMONSTER)
You can not put a ITR or B16 throttle body on a D16 manifold.
I would ask Edelbrock to see if they have one that fits your needs, or check with Holley.
Re: Throttle body opinions (civichbcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichbcx »</TD></TR><TR><TD CLASS="quote">You can not put a ITR or B16 throttle body on a D16 manifold.
I would ask Edelbrock to see if they have one that fits your needs, or check with Holley.</TD></TR></TABLE>
all b series tb's are compatable for d series, maybe you should search before you try and give someone the wrong info
thats weird cuz i had one on my ******* car you dumbshit
spettinger
07-09-2002 04:11 PM
spettinger
05-21-2002 02:18 PM
