99 civic rywire harness
Old 04-03-2014, 04:17 PM
Mike_ef's Avatar
Icon6 99 civic rywire harness
okay so i recently purchased a bseries wiring harness. the motor is obd2 and the ecu is obd1. i decided to go this route because the previous owner hacked the oem harness together and i did not want to deal with that mess anymore. im am confused as to where these wires go that i have pictured. everything else seems to be plug and play. i already tried contacting rywire multiple times and no answer so i figured id make a posting to see if any of you guys could help me out. if this doesn't work i will send an email to them also. another thing i noticed about the rywire harness is that it did not come with the plug on the bottom of the motor. i believe it is called the crank position sensor? will the car run fine without this?
i also noticed that there are only 5 wires into the green plug, and the oem one has seven going into it i believe.
Old 04-03-2014, 04:18 PM
Mike_ef's Avatar
Default Re: 99 civic rywire harness
obd2b...
Old 04-04-2014, 01:01 PM
Mike_ef's Avatar
Bumpppp
Old 04-04-2014, 01:41 PM
Seagull Management
94EG8's Avatar
What year civic and trim level and what year harness? '96 - '98 Civics use a different harness than '99 - '00 and they aren't interchangeable. HXs and GXs are a bit weird though, the HX is OBD2A all the way through production and the GX is OBD2B all the way through production.
Old 04-04-2014, 03:11 PM
Mike_ef's Avatar
its a 99 cx hatch and its a budget b-series engine harness. harness: chassis:99-00 civic
engine: b-series
ecu: obd1
diz: alt: inj: obd2
mil-spec chassis adapter (ek2b)
$MIKE$
06-12-2014 02:04 PM
smagiske6
07-16-2012 10:55 PM
prime-R
12
04-02-2009 04:15 PM
adictionbass
10-29-2008 12:22 PM
oneforce
04-24-2006 10:21 AM
Quick Reply: 99 civic rywire harness
